Not a hugely productive day but worked on the aileron trim tab and associated access hatch which were not pre-cut or drilled which made for quite a bit of cutting and filing to get a professional looking finish. Managed to attach the aileron trim tab with good clearance and work around a movement restriction on the trim tab piano hinge.
The location of the trim servo access hatch are incorrect on the plans andthus a bit of manual work went into getting the right location and an approrpaitely finished access hole which was completed by the end of the day.
Also spent time taking over the study to create a large work bench for the construction of the wings. Did not finish the workbench due to a lack of materials but got over 50% of the way.
