Started work on the right aileron (with help from Emma and Ethan). The right aileron requires a cut out that was not pre-cut on the aileron skin by the manufacturer for the aileron trim tab. I used an olfa knife to get a nice clean straight cut and it worked out pretty well.
Will also have to do a cut out for the access hole which is also not pre-cut on the aileron skin. I seem to be missing two internal ribs that are required for the mass balance upgrade. No idea where these are as I signed for them from the local distributor and have the rest of the upgrade kit but cannot find these for the life of me. I will have to reorder these from the States.
