James Roberts RV8 Build
Date:  12-31-2013
Number of Hours:  3.50
Brief Description:  Attaching the elevator to the horizontal stabilise
After having closed up the elevator I needed to attach the elevator to the horizontal stabiliser by drill out the piano hinge and positioning it correctly. Not a particularly hard job but rewarding nevertheless as this is the first time that you see most of the tail feathers on the aircraft at the same time.
Also spent some time on the aileron trim cut out for the elevator. There is a little bit of a restriction on the movement of the trim table so I am slowly shaving off millimeters to get a proper range of motion before final assembly on this part.
