Decided to paint the rear baggage shelf today. While the other days painting had been successful, I learnt a fair lesson here that in leaning over the aircraft to spray I did not maintain an exact distance between the gun and surface. This resulted (at the end nog al) in spraying solid/dried paint particles onto a wet surface.
As a result I will have to sand down a lot of the surface and reapply a top coat to fix this. The irony is that most of the affected area will be under carpet (but I'll know its there).
