Put the sub panels on the forward fuselage. I knew wasn't going to fit just right due to the earlier mis-measurement earlier. As it turns out it left a 1,4 inch gap (not as bad as I thought). I made four spacers out of 1/8th inch angle. I'll drill those later. Moving on, I test fit the air vents and realized that I don't like them. I'm officially shopping for better vents, probably all aluminum because the plastic just isn't right.
