Wow did I get a lot done today. I started early and finished up the tank attach bracket then moved on to the capacitive fuel senders. After that I made the big cut in the inboard end rib then drilled and installed the retainer ring, nut plates and anti-hang-up bracket. Driled the holes in the nose for the flop tube and stiffener remembering (this time) to leave room for the nut that tightens the fuel elbow. I was on such a role I figured I'd see how far I could get on prepping all the holes. I drilled, dimpled or countersunk all the holes for the filler neck, drain, and outboard bung for the ER tank. Went ahead and made the trap door on the next to most inboard rib (this one moves more smoothly than the left one). Then I deburred and dimpled everything including the skin and stiffeners. So I'm ready for the proseal tomorrow...woo hoo!!
