Did some more work on the ER tanks. I got the fuel pump installed and fabricated the fuel transfer tubes. Realized that I'm going to have to relocated the ground for the landing light since there wont be enough slack to change the bulb through the front and there's not going to be any access from the rear without moving the ER tank. I figure it's easier to build in some slack now rather than remove the main fuel tank every time I have to change a bulb. Can't go any further until I wire up the fuel pump and I can't do that until I have a bushing and some more wire and terminals. All that stuff is already on order from Stein so I wrapped it up for the day.
