Finished up counterskinking the spar for the #8 fuel tank attach points and the # 6 inspection access panels. I had done a lot of reading about this process. The Vans way works out just fine and has to be at least twice as fast as any other method I've seen. Also, hit the countersinks and nut plates with primer and called it a night.
