Finally got up the courage to drill the rear spar. I had to take the right wing off and grind down the forward bracket. After I did that both wing's sweep fell right into place. Checked the sweep, incidence, level about 10 times. After I was convinced everything was good, (within 0.1") all around, drilled the spars and installed the two AN5 bolts. Solid as a rock.
