I did the final install on the ER tank today. I extended the wires on the landing light so that I'll have some slack to replace bulbs in the future. Tthere's no way to get in there without taking the ER tank out, so it will have to come out the front. I have a 12 volt power source now so I was able to make sure all the connections work, and I also leak tested the ER tank, the pump seems to work fine with all the new connections.
