Mattch drilled the hole for the nose gear to the engine mount. The reamer I bought from AC Sprue wouldn't produce any prrogress toward the tapered pin I'm trying to install so I moved on and bought another one from eBay. Moved on to the engine monnt. The engine mount hold drilled unevenfully. Engine mount drilled....just need to finish the bolts.
