Got a shipment from AC Spruce so there's several projects that got finished up today. First the parking brake needed to be mounted. Started by making a firewall doubler to mount it to, then drilled the parking brake to it with two screws and nutplates. Loosly installed three firewall penetration points for all three control cables. Fabricated and drilled the copper connection between the two solinoids. Moved on to the ground system. Installed a 49 pin grounding block then make the ground wire from the battery to the ground point.
