Worked on the roll bar all day. I used a rivet fan and masking tape to lay out the locations. It seems to work well but it was tedious. I can't believe it took this long to do this relatively simple part but since the holes are pre punched everything has to be located which easily doubles the time. I'll knock out the rest of the holes tomorrow and start fitting the the fuselage.
