Brief Description: Match drilled forward upper skin; panel brackets
Matched drilled the forward upper skin to the front deck supports and firewall. Once fully clecoed in place, I then installed the panel frame brackets where the panel attaches to the fuselage.
The panel in the picture was cut for the GRT two-EFIS system which I will likely change (either to a hi-res GRT or AFS... either way the panel would need to be laid out differently.)
