Brief Description: Finished front deck supports and panel frame
Cut the right support rib back to clear the EFIS/guages on the right panel and fabricated a stiffening angle. Fit the top flanges to the panel frame and made more suport angles for the radio stack.
Primed all of the parts and then assembled the frame, plate nuts and the ribs and support angles. I am leaving the whole assembly in pieces for now as I don't plan on installing it in the fuselage yet.
