Schroeders Sportsman
Date:  4-23-2010
Number of Hours:  1.30
Manual Reference:  p21
Brief Description:  Rudder Pedals #1
I aligned and fit the right rudder pedal weldmounts. I deburred the 4 holes and got the hardware to install the weldmounts. I have to get some help to stake one of the bushings. The hole drilled in the tab in the cage was a hair large. You coudl "press the bushing" in with your finger and push it back out. That will have to be tighter, but I need a third set of hands to support the tab while I stake it from the other side. I used some locktite and a C clamp to hold it for now. I also measured the rudder pedals out of the stock provided. I will head to the shear and brake to form them up.
