I check for twist and then aligned the lower skin on the right aileron. After side clamping it in place I checked twist again and drilled the spar. I then aligned the tail and nose ribs and drilled them. after all was finished and clecos were in place I checked for twist again. After my Horizontal Stabilizer expirence I am paranoid on ensuring twist does not sneak in.
