I dimpled the fuel pump doublers and countersunk the trippler. I also laid out the hole for the eye bolt used for the wing support used during wing folding. I pilot drilled #30 then up to final size #10 screw hole. The nutplate called for in the plans does not fit between the rivets so I'll have to mount it on an angle watching the edge distance on the aft rivet.
