I squared the inboard flap tracks and drilled the upper inboard skin. I had to open up the notch in the top skin for the track clearance. I started laying out the flap track brackets but edge distance and spacing are causing problems. I will scrap the set I started tonight, luckly I did not drill these into the spar, and learn from what I did tonight to get another set together. This may take some time.
