Thanks Mike C for the loan of the dimpling table. I finished up dimpling all the holes that could not be dimpled from the edge or inspection hole access on the six bottom skins. I will clean and prime then I am ready to install. I also was pointed out that my 1/8th dimpler was deforming the metal around the dimple and it was a die problem. I got new dies before the mains, but had to use the setup in pic #3 to allo access to redimple the nose skins. All is done and tomorrow I recheck plumb/ straight and true and start riveting it all together.
