It was a 0500 start for the day I can't thank my buddy Brent Owens enough. He is an early riser and said 0500 is the time he can start so I brewed the coffee and away we went. We got all the nose ribs riveted then riveted the leading edge together. I cleco'd the leading edge to the forward spar. I then installed the bottom inboard and center skins to mark and cut the flap bracket cutouts. I finished both wings. I also drilled the bottom side of a replacement cove rib deburred/ dimpled/ and primed the rib. I cleaned off the workbench and setup the next step deburring the dimpling the bottom main skins. Great Day!
