I measured the holes then drilled a #40 pilot hole then drill it up to 3/16 for the screw. Since the upper inboard main skins were off I countersunk this screw holes. I have to remove the lower main skins and repeat. I will then be off to disassembly of the skins and dimpling and priming for installation.
