I fit and cut the doubler to the pitot mast then transfered the hole to the wing skin. I then cut the mast to length and squared it up on both ends. I marked and drilled the screw holes to the pitot tube and the #30 holes on the opposite end of the mast for angle brackets which will be riveted to secure the mast to the double in the final instillation.
