This is a careful fit. Make sure you check the main ribs at station 69.0 and your root rib carefully. Mine turned out OK, but I had one prepunched hole that looks like it will interfere with one of the root rib reinforcements. I drilled the upper side and drilled a bit below the prepunch to eliminate the interference with the root rib reinforcement angle. Only one snag I hit all else went well.
