I broke out and prepped the bearing housings for priming. I also riveted the bellcrank assemblies together. This was my chance to use a borrowed hand squeezer from Brent Owens. (I wanted to try the one from Avery that uses pneumatic yokes) I think I like it better for the larger rivets. I am heading home for Easter tomorrow morning and I will use Dad's press to press the bearings in the aileron assemblies, bearing housings for flaps and the bearings that go into the flap brackets. That will be work for tomorrow.
