I drew the layout diagram with a reference line and the 16 and 83 degree lines as outlined in the manual. I also had a good bit of help from a fellow sportsman builder Joe Marconi with a template and I had a brain cramp in the morning he helped me work that out. First step was getting the rivet pattern laid out and drilled through all parts. Next we went on to priming and reassemble. This was my chance to use a borrowed hand squeezer from Brent Owens. (I wanted to try the one from Avery that uses pneumatic yokes)
