Brief Description: Drilled and reammed strut beams/ bellcranks
Drilled and reamed (Thanks Brent) the bolt attach holes. I temporarily assembled the strut beams and measured to double check that I had 21.75 tollerance. I also primed the bellcrank bearing assembly being careful not to get primer on the bearing themselves. I fit the bell cranks and sized the rivets for putting them together tomorrow night.
