I started the day with double checking the fit of bulkhead B and cutting out the center section. I beveled the edges and cut bid to lay over the belly seam. I also mixed QCell mix to set the cage attache brackets on the sides and rear of the cage. I fired up the catalyst and got a start on the belly seam layups.
