I sanded the shell and front cage attach points then cut the bid for making the attach points. I've epoxied them in place and covered them in peel ply. I also got my shipment of Zolotone touch up and cage touch paint. I used the cage touch up to give my side and rear attach brackets a coat. I wanted them to match the cage. I also got bulkhead B 90% fit. I wanted to walk away and get a fresh eye on it tomorrow. Then I'll seal the foam and cut the center section out of it and get a layer or two of bid on them.
