I mixed some filler for the dorsal seam and laid up a couple of layers of glass to help shim one of the aft cage attach points. I sanded the dorsal seam and belly seam outside with the DA sander. I also used plastic wrap to get the layup pattern for the turtle deck. I cut the glass and laid up the glass per plans and covered it with peel ply. This peal ply has been a useful little tool in keeping sanding down to a minimum. Good days work.
