I fit the top deck and the prepped for bonding. I drilled clecos and waxed up a batch to hold things in place during bonding. I bought a electric heater to set into the fuselage and keep the heat up. I also covered the fuselage with a tarp to keep the heat in a bit. The thermometer I had on the deck looked like it kept a good 60ish degrees through the night.
