Schroeders Sportsman
Date:  10-20-2009
Number of Hours:  1.20
Manual Reference:  p9
Brief Description:  Fuselage Surgery
After fitting the doors I realized that one of the cage tab interfered with the shell enough to cause the door to fit badly. I did a little composite surgery as described in the manual and beveled the edges with a little cabosil mixture and a layer of bid. I will let it cure then drill the left side of the fuselage and connect the hardware.
