Brief Description: Drill and secure the bottom cage
I drilled the tab hole a bit undersized from the top then drill up to #10 from the bottom and counter sunk the holes. I did only the front two tabs just to get the technique down. I also set up the microstop for the countersunk screws. I only got tow in but I got the technique down where the screw is nice and flush with the outside of the aircraft.
