I sanded and prepped the dorsal seam to include the area that the two shells and the right half of the tail join up. I used side clamps and rough fit the tail in and drilled the 5 aft most holes to tie in the shells. I had a great help form my daughter Nicole, we whipped up a batch of VE epoxy and used a 2 in chip brush I cut the bristles down on. That spread epoxy like a dream. I also did the nose seam at the base of the windshield. I also got a hold of some cardboard and rough cut the bulkhead templates. I scared up the foam for cutting later.
