Schroeders Sportsman
Date:  4-12-2014
Number of Hours:  2.60
Brief Description:  Fresh air vents
Lots of sanding today. I was happy with the right outside but needed a bit more fill on the left outside. I also did the knuckle busting sanding on the inside left and right. I did a bit more fill on the inside left and right. I mixed it thick but not thick enough or I put on a bit to much and a had a few runs. Nothing a bit of grinding and sanding won't cure.
