I had glass cut for the underside of the turtle deck. I did the top side in Ohio and time to finish the bottom side. I also did a lot of work on the rudder pedals I laid out the back bracket locations, pressed the bearings, drilled the rivet holes, cut the brackets for brake master cylinder connect, primed the brackets, cleaned it all up and riveted it together. I got all 4 done.
