I marked and drilled the brackets for the upper aft cage attach. I painted this bracket and the left aft side attach brackets to match the cage powder coat. The big job tonight was marking the internal layers of glass for reinforcing the turtle deck and aft fuselage. I used the same technique as I did for the upper layers. I used the template to cut glass ready to do the lay up.
