I drilled out the rivets for the forward fuselage attach brackets. I realized that I had only put one layer when it called for 4 layers. I cut the glass for all 4 tabs and soem additional glass for the HS stab shim. Next is fire up some resin and get them in place. A bit of rework, but it has to be done.
