I primed the elevator pushrod and riveted one end. I'll have to cut the other end to length later in the build. I also primed the elevator bellcrank and stop plate. I scared up the hardware and it is ready for instalation. I also reattached the HS stab forward bracket to fit the HS stab after a bit of sanding to the fiberglass shim in installed.
