I glased first thing int he morning then set up the light to cure it out quickly. I drilled the holes to attach the bracket and bolted things back in place. Of course the fiberglass shim is to much so sanding is in order. The tollerance is +/- and inch at the tip of the HS stab. I am about an inch out which is about 2 layers of glass.
