I cut and fit the cardboard templates for the sheerweb. I then transfered the template to the 6061 and cut it. I then worked to the final fit. I also cleaned up the hole which allows clearence for he lower rudder hinge. I remounted the HS stab mounting bracket in preperation for fiting.
