Today was a productive day, but it was fixing a problem. I cut the center out of BH C per the template and it took to much material from the upper portion. So I cut, fit and bonded plugs back in the left and right side of the rudder hinge. I used a mixture of milled fiber and flox to bond the plug. I then did 2 layers of bid on each side of the BH. I also tracked down my forward shearweb template and cut cardboard I can do the fitting with before cutting metal. I did some tracking of parts down for the next steps. We'll see how it looks tomorrow.
