Joe Marconi was over tonight and helped align and place bulkhead D. We double checked the fuselage level and then used the digital level to make sure were were aligned vertically. Next we squared it and confirmed our alignement by measuring the top corners from cage strut attach point. All lined up good. Joe came up with the good idea of using some slats spring clipped it to keep the bulkhead in place and aligned. It worked well. I kept the light on it over night and it cured out well. Thank Joe for your help!.
