I finished up the rudder stop and ensured it has 25 degrees of travel left and right. I installed the rudder stop guards against bulkhead C. I primed and riveted my rudder stop to the rudder horn. All went well. I did started to fit my elevator bellcrank brackets. I jumped the gun and drilled the holes before I fit it. Wrong. I had to trim a good bit off the outside ends of the brackets to get it to fit in between the shells and I ate away my edge distance on the outside holes. It should be a cheap shipment and I'll get my fuel pump thrown in.
