I got my vertical spar primed with the hinges. I drew the rivet line on the right side of the vertical and when I looked at the one I did previously. I have one bit of the fuselage shell which is a little shy on edge distance. I am going to add 2-3 layers of glass in there and trim it back to get the proper distance in there. A little disappointed they would not error on leaving to much material and make the builder sand it away. Well it is not a show stopper just a bit of extra work.
