Brief Description: Position elevator hinge and drill index holes
After much thought measurement thought and many more measurements I positioned and drilled the index holes for the elevator hinge. A critical step and I picked up a couple of helpful hints. One thing that helped was working the trim tab first. This helped me pick up the method for installing these hinges. The other thing which was helpful was stretching a fish line 1 inch forward of the hinge line. This provided a good datum line to work the alignment of all three elevator hinges. The other useful item with the hinge bit I used to start the index hole. This bit helps center you hole in the dimple. I finished it with the #30 and cleco'd. We'll see how it all turns out, but so far so good.
