Rechecked the elevator control force and moved on to rebuild the can buss connection to address my comm radios not integrating with the G3X. After testing that was not the problem. i moved to pull, clean reassemble the left fuel transfer pump. Affter a bench test it worked and I reinstalled and tested on the aircraft. One item crossed off the squawk list.
