I rigged up a drain line a the fuel spider and turned on the boost pump to pump the fuel from the left main. I also pumped from the right side and transfered fuel from the aux tanks. I did find a fuel leak durring testing. i'll have to tackle that one later but that is why we test.Last I did was install the battery that goes in the ELT remor panel.
