Schroeders Sportsman
Date:  2-20-2015
Number of Hours:  0.60
Brief Description:  Instrument Panel
I bought the Zach Chase instrument panel and had to cut the tabs off the cage where the factory panel mounts. I cut off the six rear facing tabs and the two verticle tabs. I ground down the welds a bit only grinding only what was necessary to create the clearance I needed.
