Schroeders Sportsman
Date:  5-8-2014
Number of Hours:  2.30
Brief Description:  Back of the engine work
I started work on the back of the engine. I had to pull the engine driven fuel pump and a few of the bolts in the prop governor to get the control bracket on. After pullin the pump there was a bit of grind a fit for the shroud. I got that down to a good fit. Double check tomorrow.
